Old 7-Dec-2011, 10:44 PM   #10
phone man
Originally Posted by doubler View Post
I have another puzzling question I unhooked my pre amp and locked on channel 11 only and its been rainy and cloudy for 2 days do you think it could be over saturating with the preamp hooked up?
By unhooked the amp you mean you went up on the roof and completely removed the preamp and now have a single uninterrupted run of coax going from the antenna to the TV? Or did you just bypass the power inserter for the preamp?
GUM asked a good question earlier. Is this a new installation that hasn't quite worked right or did your OTA setup work fine but now has a problem?
phone man is offline   Reply With Quote
