Old 1-Dec-2011, 8:17 PM   #3
Originally Posted by Electron View Post
The tv stations to the west in the yellow and pink zones are all UHF channels. Install a Winegard HD9095 antenna pointed at the group of stations to the west. Connect the antenna to Channel Master CM3414 distribution amplifier , 4 way distribution amplifier. http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.amazon.com
I would use a very similar system. The antenna already suggested or an Antennas Direct XG91.
Instead of the CM3414, I would use an Antennas Direct CPA-18 mounted outside at the antenna. (The attic will attenuate already weak signals.) You will get slightly better signal-to-noise ratio (better signal quality) by placing the preamp close to the antenna as opposed to some distance away. The loss in the coax will reduce the signal-to-noise ratio and an amplifier will not be able to recover that signal-to-noise ratio. A passive 4-way splitter can then be located inside wherever it's convenient.
