Can you install an Antennas Direct XG-91? Buffalo signals are going to require the highest gain UHF antenna available. Even then, don't expect reliable reception due to the obstructions, weak signal conditions, adjacent and co-channel interference and strong local signals including FM stations.
Reception of the locals could be doable with an indoor antenna such as the Terk HDTVi or an RCA ANT-751 mounted outside.
