Old 1-Dec-2011, 6:35 PM   #2
It looks like you would do fairly well with a Winegard HD7698P and a rotator. I would also expect you would need a preamp such as the Antennas Direct CPA-18 or Winegard AP8700.
I would suggest using a 10' mast section with the tripod. Extra elevation will be helpful and you'll get more distance from the metal roof.
The NTE TB-105 is a good investment if you are putting a large antenna on a rotator. It will reduce the stress on the rotator a great deal. http://www.nteinc.com/ecgproducts/pd...na_rotator.pdf
