Thread: Antenna Upgrade
Old 1-Dec-2011, 6:09 PM   #1
kw52981
Antenna Upgrade
TV Fool Results
Height was set to 35'.
Close to a downtown however all large structures are not in the direction of TV signals.
Interested in channels 2, 8, 12 26, 45. Anything else is a bonus.
Currently using a Weinguard MS200 mounted above the roof level. Ths was previously mounted in the attic. When it was moved outside little or no improvemet in signal. The signal is currently watchable. Signal drops out on a regular (once per 2 min or so) basis.
I have looked through forum topics but have yet to find someone in a similar situation , i.e. with major stations at or near 180 degrees of each other.
My ideal setup would be to have a attic mounted antenna(s). This will be serving three devices, HTPC and 2 TVS(one with DTV tuner and one currently still using a converter box).
Any help is greatly appreciated!
kw52981 is offline   Reply With Quote
