Old 1-Dec-2011, 5:42 AM   #2
You appear to be blocked by terrain. If you can't consider a tower, a rotator and the largest directional antennas available for UHF and high-VHF... Then I don't see any realistic hope of reliable reception at your location.
This path profile tells a sad tale. http://www.tvfool.com/?option=com_wr...dALLTV%26n%3d2 Only the largest high gain UHF and high-VHF antenna combinations would give you a chance at reception... You would be doing extremely well to get somewhat reliable reception of more than two or three stations.
I took the liberty to reverse engineer you location to somewhere near Long Meadow Hill. That looks like a good antenna location. http://www.tvfool.com/?option=com_wr...ec12d2383c8c01
I presume an idea such as this http://forum.tvfool.com/showthread.php?t=1286 would fit in the category of "major PITA".
Last edited by GroundUrMast; 1-Dec-2011 at 8:45 PM. Reason: Added link to path profile
