It is improbable that you will achieve reliable reception of any of the nearby ABC affiliates (WTHN - RF10 from Harrisburg, WPVI - RF6 from Philadelphia, or WMAR- RF38 from Baltimore) with any indoor antenna. Signal levels are low, interference levels are high, and any prediction for indoors reception is little more than an educated guess, at best.
A roof-mounted antenna that covers the correct RF channel listed above would be the minimum requirement. As each of those stations transmits on different bands (low-VHF, high-VHF, and UHF), each has a different requirement for the optimal antenna for reception.
You may wish to read the "Guidelines when asking for help" at the top of this forum section so that you know what information is needed for other forum participants use to make an informed recommendation for you.
