Old 30-Nov-2011, 5:16 PM   #3
dodgeman1973
All of the cable and connectors should be inspected for signs of corrosion or water intrusion. Once water has entered the coax, it should be replaced.
If you can consider a tower or other means to safely mount higher, it would be helpful to see a TVFR based on the higher AGL.
If I were starting from scratch, using the 25' AGL signal predictions, I'd opt for a big all channel antenna such as the Winegard HD8200U and a high input preamp such as the Winegard HDP-269 or the Antennas Direct CPA-19.
If your existing antenna does not have bent or broken parts and the connection terminals are not corroded, you may want to try adding a preamp before replacing the antenna.
thanks!! a few of the vhf elements are bent.
dodgeman1973 is offline   Reply With Quote
