The thing that jumps out at me is that you are splitting your signal nine ways to Sunday for reasons that are not terribly clear. Three separate HTPC tuners? There are HTPC tuners that tune two channels at the same time. Would it not be better to connect your antenna to your Slingbox and let it distribute your signals? The takeaway message is that you have chosen a brute force solution for what you want to do. You should consider a more elegant solution.
