Old 30-Nov-2011, 7:26 AM   #6
Originally Posted by jazz View Post
Thank you both. I am not interested in picking up stations from Montreal and an attic installation is my preference. I went to the Winegard website and found the HD7694P that you recommended. From the website, I saw the following... "Please be aware that attic installations will reduce signal by 50% and roofing made of cement tile, clay tiles or metal will reduce signal by 90%." My roof is made of wooden trusses, plywood and asphalt singles. Any issue?
Also, the spec sheet recommends a AP Series pre-amp. Is that necessary for my application?
Thanks.
Your attic construction sounds like it will work... The real test requires putting an antenna up there. As I mentioned previously, a load of wet snow will be the ultimate test for your installation.
How many sets will you connect and how many feet of coax will be run from the antenna to the farthest set? For a single TV and 100 feet or less coax, I would definitely try the install with no amplifier.
