Old 30-Nov-2011, 1:40 AM   #5
jazz
Thank you both. I am not interested in picking up stations from Montreal and an attic installation is my preference. I went to the Winegard website and found the HD7694P that you recommended. From the website, I saw the following... "Please be aware that attic installations will reduce signal by 50% and roofing made of cement tile, clay tiles or metal will reduce signal by 90%." My roof is made of wooden trusses, plywood and asphalt singles. Any issue?
Also, the spec sheet recommends a AP Series pre-amp. Is that necessary for my application?
Thanks.
jazz is offline   Reply With Quote
