Old 28-Nov-2011, 2:05 AM   #3
MisterMe
Why do your product research after the purchase? I assume that you will discretely mount your antenna outside. With the VHF elements installed, you should have no trouble receiving the top 14 stations all the way down to KGO-DT (RF 7). That said, you do not need the preamp. Since you already have the preamp, you may test it to see if it improves your reception.
