Old 26-Nov-2011, 10:09 PM   #22
skatingrocker17
Originally Posted by MisterMe View Post
The fact that you are trying to receive out-of-market channels will not make your in-market channels magically disappear.
Did I say it would? I was saying that even though I aimed it in another direction they still come in just fine and while it's aimed in another direction the pre-amp appears to help. Like I said earlier, it didn't really help get me a lot more channels however it did fix the little studders I had with my local Fox station.
You appear to be trying to bargain with members of this forum to allow you to receive additional channels with your preamp. No one here has any control over your preamp. Your preamp's effectiveness is determined by its specifications and the aggregated strengths of the signals that it receives.
How so? I'm just trying to learn more about it (in this case the pre-amp) and I've shared my experiences with it. I'm not asking for channels here, how could I? I know it's not even really possible without a larger antenna at a higher height.
I'm betting dollars to donuts that you received 20 extra sub-channels on many fewer unique RF channels. For a given RF channel, if you receive one of its sub-channels, then you will receive all of its sub-channels.
Obviously, I take it you just assume that by the fact that I named every channel (excluding sub-channels unless it was another major network). Take the Dayton PBS for example, that 5 channels right there.
skatingrocker17 is offline   Reply With Quote
