Old 26-Nov-2011, 1:10 AM   #18
skatingrocker17
To see Fort Wayne reliably you'll need a 80 to 100' tower and a big UHF antenna such as the Antennas Direct XG91.
The AP8275 is easy to overload, it's only spec'd to handle 30,000 micro-volts of combined UHF input. I wonder how you would do if you completely removed the preamp and power supply... You may actually see more, not less.
Then what's the point of the pre-amp? I thought it would only hurt the signal if the stations were too close?
Edit: 12:27am and still no extra channels ):
skatingrocker17 is offline   Reply With Quote
