If you're pickup up two of those stations, even with drop outs, with rabbit ears and a UHF loop, I'l bet a decent roof mounted antenna will work just fine. Have you considered a single antenna solution such as the 4228HD? It's rated for high VHF as well as UHF which would cover all your stations including ch 9. My signal strength and distance to towers is very similar to yours and I'm dealing with 2 edge reception and a ragged horizon as well.
With the 4228HD and CPA-19 preamp I have no problems getting channels 40 to 65 miles away.
