Old 8-May-2010, 12:18 AM   #8
mgullick
I posted this on another forum before reading Tigerbangs recommendation.
Plan on a rotor and a 7-69 antenna such as the HBU-22 or HD7694P.
OR
My preference would be a two or four bay UHF and a 5 element High band VHF with a UVSJ. (Channel Master 4220 HD with an Antennacraft Y5-7-13.)
Aim the 4220 between NBC and the other UHF stations. (roughly 5 degrees) The VHF yagi gets aimed at 323 degrees. The two antenna solution will be cheaper than a rotor and simpler to use. It's about the same size as a single antenna.
How does the Antennacraft Y5-7-13 above compare with the Winegard YA-6713? Is one preferable over the other? I'm also wondering if you have a recommendation as to an online source that has good pricing and doesn't have outrageous shipping costs.
mgullick is offline   Reply With Quote
