Old 23-Nov-2011, 6:54 PM   #5
Jammer
HBU33 is the better antenna.
Be sure you have it pointed to the southeast. The narrow end (with the smaller rods) is the part that should point southeast.
I would guess that part of the problem is that WATC is so close it's soaking the receiver. A properly pointed directional antenna should help with that.
Hard to tell on how you'll do in the attic. Maybe someone more knowledgeable will come along and comment. It might help to re-run the signal analysis with the height set to your attic height as often just 10 feet of elevation can make a huge difference.
Jammer is offline   Reply With Quote
