Old 23-Nov-2011, 2:06 PM   #15
jeffj318
Originally Posted by No static at all View Post
Will your wife go for a small, fairly inconspicuous antenna? Once on the roof this antenna is nearly invisible.
Another option is this antenna if you won't need CBS or NBC.
I doubt an attic antenna will provide reliable reception of FOX as the transmitter power aimed in your direction is greatly reduced.
Looks like these antenna go about 30 miles. We are about 50 miles from either Baltimore or Philly. Roof top probably okay for Philly due to weather forecasts being more like where we live. How do I find someone to mount the antenna and guide the wire to the TV on the lower level? Could I use the same location the dish is now and guide the wire through the same location? Only using one TV. Will need CBS and NBC as well as Fox Network. Would this work .... http://www.amazon.com/Antennas-Direc...pr_product_top
jeffj318 is offline   Reply With Quote
