No worries. You need an antenna that covers Hi-VHF and UHF. Two brands come highly recommended: a Winegard HD7695P and an AntennaCraft HBU-33 should work in the attic. You can save a little money by mounting on the roof, as the HD7694 would do the trick there. You might need a preamp with the attic install (overcomes cable loss that might leave your reception susceptible to fades.
