There is a difference between the EZ HD antenna and the ANT 751. Yes, the antennas are made by the same manufacturer and with my permission RCA is allowed to market the ANT 751. In 2009 at the time of the analog shutdown the EZ HD was re-tuned and cut to the new and current digital frequencies and the ANT 751 was not. The UHF gain of the EZ HD antenna is greater than that of the ANT 751. The new improved frequency tuned EZ HD was tested against the ANT 751 on the same test range and the average UHF signal gain was improved by 2.2 dB.
I don't know where you get your info. Electron but it is incorrect.
Denny
Denny's Antenna Service
