Tigerbangs and teleview,
Thanks for the advice. I found out today from my builder that the house will have structured wiring with an RG6 and CAT6 wires running to all Bedrooms and Living room, which is where the main TV will be.
Teleview, you got me thinking so I asked the builder if he would run an extra RG6 from the antenna location to the structured wiring box. This way I should be able to pipe the signal into a splitter to any room in the future. The distance from the antenna to the SW box will now be about 25-30 feet. Then the run back to the main TV from the SW box will be another 25-30 feet. This will be the only TV for now.
Tigerbands, you mentioned and provided a link for an amplifier, at what point do you think I would need this when I start adding more rooms, or do I need it now based on the new wire length?
Again, your advice is golden...
