Old 6-May-2010, 4:47 PM   #4
Dave Loudin
On that page, under the question "What types of antennas are covered by the rule?", item 3) has your answer:
An antenna that is designed to receive local television broadcast signals. Masts higher than 12 feet above the roofline may be subject to local permitting requirements.
There is no restriction on size here. The 1-meter size applies to dishes and wireless cable antennas. However, the following clouds the issue a little:
Q: I want a conventional "stick" antenna to receive a distant over-the air television signal. Does the rule apply to me?
A: No. The rule does not apply to television antennas used to receive a distant signal.
I'm not quite sure what is meant here.
