Old 18-Nov-2011, 8:37 AM   #3
Chey_user
Cheyenne reception follow-up
Thank you. I appreciate your recommendations. Oddly enough, I am picking up one station KTWO-SD (ABC) with the amplified RCA antenna that is not revealed thru online searches. When I run antennaweb.org for my address, it does identify a NBC station tower (KCHY-LP Real channel 13, (lt green vhf) at 75 deg, 5.4 mi.. I have not been able to receive it or any of the 2 PBS station signals with my current setup, so I am planning to purchase Terk. Would you recommend the amplified, Terk HDTVa? If it doesn't work, I would consider a small outside antenna positioned at discrete location. I noticed Terk has a small outside antenna option.
Chey_user is offline   Reply With Quote
