Old 17-Nov-2011, 6:11 PM   #4
The DB-8 is a UHF antenna, it's not designed to receive VHF channels 2 through 13. That does not mean it will block all signal from VHF stations. The DB-8 is not efficient at converting VHF electromagnetic signal in the air to electrical signal in the coax cable.
You have described a problem that is best solved as TG has already suggested. Reliable reception depends on the correct antenna and it's placement.
A preamp can not remove noise or interference from a weak signal, but the correct antenna can recover a stronger signal with less interference.
If you want to spend money on a preamp, the Winegard HDP-269 and Antennas Direct CPA-19 will be least likely to overload due to the many other strong local signals. I don't expect any preamp will make your very good UHF antenna into a fair VHF antenna.
If I dug a shallow well and complained that I keep running out of clean water, would you tell me to get a high pressure pump, or dig the well deeper?
