Old 16-Nov-2011, 6:12 AM   #6
The splitter is easy to change out and not too expensive. But splitters are generally quite reliable...
I've been holding back, from suggesting that you replace the ANT-806. Before I seriously suggest that, try a new splitter rated for 5 to 1000 MHz... the Ideal brand product at Home Depot for example. The 2 GHz splitter is not 'wrong' but the over the air TV signals range between 54 and 698 MHz. No need to spend money on unusable bandwidth.
I would also like to see you try moving the antenna in the attic... up, down, left or right. Even test reception with the antenna outside in the clear. Attics can be tough antenna locations. I would like to rule out the attic location as a cause for marginal signal quality.
