Old 15-Nov-2011, 3:49 AM   #2
I would expect the ANT-751 to be marginal at best in the attic. I think you'll need more gain as the roof gets wet. If you get snow on the roof expect to have trouble with the weaker signals.
A Winegard HD7694P or larger aimed at about 314° would be a better single antenna choice.
The 8-bay panel is easier to fit in most attics but it is a UHF only solution so you would need a high-VHF antenna off to the side somewhere in the attic if you want to see WHAS and WBNA, real channels 11 and 8.
