To back up what @ADTech said, you need only one antenna. What you don't realize is that antennas do pick some signal from the back. Since your signals are so strong, you do not need much antenna gain. What you need is an antenna that has modest gain over a broad range of azimuth. Do what ADTech suggested to accomplish this. I hope you can return the other antennas.
