Old 14-Nov-2011, 11:05 PM   #10
My Plan is to mount Channel Master 4220MHD antenna on same pole as my CS 4 and combine them with UHF/VHF splitter/combiner in order to improve my signal for 11-X (ABC) and 47-X Channels (iON)?
Also planning to put a C2 Clear Stream 2 (Facing N-NE approx 120 Degrees) and combine it with rest of the antennas connection ?
No and no.
You cannot use a UVSJ to combine a U/V signal with a U signal. They're for combining a U signal with a V signal only. The 4220 is a U antenna.
Adding another U antenna with such a broad beamwidth as the C2 or 4220 to the C4 via a reversed splitter is a disaster waiting to happen. The probability of success is extremely low.
Please see my previous suggestion.
