So, you do need a cable o satellite box in order to have High definition channels.
Okay, now that's just sad coming from a TV set company.....
Please advise as to DIRECTION the front (narrow end) of the antenna is pointing. A large all-channel antenna such as that will be quite directional.
Troubleshooting tip: Bypass all that cr... er, stuff, and run a single cable temporarily to a single TV set. Program it to see what you can get. Once that is successful, then and only then, start integrating the rest of the cable distribution scheme.
