Old 3-May-2010, 7:42 PM   #4
Tower Guy
Originally Posted by Tigerbangs View Post
You are really going to need a 2-antenna solution to see all your networks, but it isn't that difficult to make this work:
I posted this on another forum before reading Tigerbangs recommendation.
Plan on a rotor and a 7-69 antenna such as the HBU-22 or HD7694P.
OR
My preference would be a two or four bay UHF and a 5 element High band VHF with a UVSJ. (Channel Master 4220 HD with an Antennacraft Y5-7-13.)
Aim the 4220 between NBC and the other UHF stations. (roughly 5 degrees) The VHF yagi gets aimed at 323 degrees. The two antenna solution will be cheaper than a rotor and simpler to use. It's about the same size as a single antenna.
