It looks as if there is limited digital deployment in your area. You would benefit from a large all channel antenna such as the Winegard HD8200U. A low noise preamp such as the Winegard HDP-269 or Antennas Direct CPA-19 would be needed to 'push' the signal down the coax.
Your report indicates 50 feet AGL as the mounting height for the antenna. Do you already have a tower?
