Thanks and some results
Thanks for the info....
Today I did some 'serious' trouble shooting. After doing a lot of the stuff you mentioned I came to the conlusion that the Distrib Amp was bad. I disconnect all and moved down to the preamp out and the distribution amp out. It all of a sudden, it seemed went blank. I connected to the pre amp out and good signals... The thing I dont understand is the signals were reasonable wether the power was on or off the preamp.
Finally I hooked all back up, by passing the distrib amp, with all 4 loads on the splitter and we have all of our channels back again with good signal levels on the 'signal meter reading'. Amazing.
I am going to blame some on the wx.... Will know more tomorrow....
have to feed the dogs and then go to a Pathway construction meeting.
