Thanks for the details.
So, 138' of RG-6 will have about 9 dB of loss at the upper end of the UHF band. (Assuming 6.5 dB loss per 100')
The AP8725 is rated at 28 dB gain (UHF). The HDA-100 is rated at 15 dB gain. Both amplifiers are rated at about 3 dB NF which means that even if the HDA-100 is not overloaded by the preamplifier the combined noise figure of the two amplifiers is about 6 dB. The NF of each amplifier is a negative, a source of noise added to the signal.
I'd like to suggest an experiment.
Try connecting a single TV to the output of the AP8725. (I'm thinking that it may be easy to disconnect the cable from the input of the HDA-100 and connect that cable to a TV.)
My suspicion is that the new antenna and coax repair is delivering more signal to the HDA-100, overloading it to some degree. I'm also thinking the AP8725 is possibly over-driven... but I don't want to make you lower the tower unless we prove the need.
