The HD7698P will have more gain on channel 7 and higher. The RCA offers support for channel 2 through 6. If your don't care about reception of W22DA (Licensed to Three Angels Broadcasting) or the two analog signals on CH-4 and CH-6, then the HD7698P will be a better antenna for you.
Mounted on a rotator, you should expect to see most of the full service stations out of Baltimore and DC. Your CM-7777 amplifier should fine, I would leave the FM trap "In".
