All of the stations in the yellow section of your TV Fool report would be with in reach with a 4-bay UHF antenna. (U4000, DB-4, CM4221, HD4400)
One caveat, with the antenna facing 131°, you may not see WUNE reliably. (The strong signals from WXII and WUNL can be expected to be picked up through the back face of the antenna.
As you start looking for signals from stations in the red section of your report, you have to start considering a significantly larger antenna and a rotator. The Antennas Direct XG-91 would not be excessive, IMO.
