Old 6-Nov-2011, 4:54 PM   #1
tvtom
tvtom
Trouble with my mast mounted antenna system
Greetings, I am a newbe to this very interesting forum. It is possible if I searched long enough I could find and put together some answers to my questions. But decided ask.
1st a summary.
I have had a mast mounted system since 2002.
Winegard AP 8275 preamp (2006)
Winegard HDA 100 distribution amp (2006)
Recently changed (last week) from a CM 3023 to Terrestrial DB8 UHF antenna (no VHF)
On rotor
Antenna is about 39 feet up, and we live on a hill
There a the tops of a couple trees for the 1st 500 feet or so of the LOS
We are 41 miles LOS South South West of South Bend IN antenna farm (east of Winamac) about
Recently I had lost some channels (the weaker ones). Decided to try the DB8 as it had more advertized gain than the CM3023.
It did not help any. I decided the problem was in the preamp or the cable.
I purchased a Radio Shack preamp (they are close out here in the boonies) in case I needed if once I dropped the tower. I discovered that the cable shielding had deteriorated greatly apparently from a coax splice I had put in near the ground and sealed with tape.
I replaced the entire cable with new rg 6u cable. Did not replace the preamp.
The results were-
The channels with previously good signals came in very good. The ones with previous moderate signals (in the middle green band on my digital converter box) were helped slightly. The antenna seemed to have a narrower pointing angle than the cm3023. but the channels with previous weak signals (PBS WNIT the main one) were zip, nothing. This channel would come in often previously. Although it does not have much power 85KW, the tower is high, 1100 feet (according to my info); it seems I should be getting that signal good with the DB8.
1- My 1st question here is - Why would the DB8 seem to pull in the previous strong signals better than the CM3023?
2- Is there experience that the DB8 has a narrower pointing angle than the 3023.?
3- I am thinking of dropping the antenna again-
a- Can I put the CM3023 up with the DB8 and connect them in parallel through an inverse splitter into the preamp on the pole, and should that help, make no difference, or?
b- Should I replace the DB8 with the CM3023
c- Should I change preamps?
Although it is not too hard to drop the tower... it is not trivial.
Thanks very much for any comments....
TVTom
tvtom is offline   Reply With Quote
