Old 6-Nov-2011, 3:05 PM   #43
tbird2340
Originally Posted by No static at all View Post
No, the antenna you have is about as good as it gets. I
Overload won't damage anything, but may compromise reception of some stations. (Usually the weakest ones will be lost or made worse) It's best to stay on the conservative side with one or more strong signals around.
It's all about experimentation. I have found a vertical sweet spot which yields excellent reception of all available stations. Just a few inches up/down on the mast makes a world of difference here.
So how do you go about adjusting?? I went on the roof w/ my cell and had my wife watching the TV while I had the debugging / signal info on the channel (KDKA).. That's the day I jacked it to the point where it wouldn't come in it all..
I would move it ever so slightly to the left/right/up/down etc.. Is that how you do it as well?
tbird2340 is offline   Reply With Quote
