Old 5-Nov-2011, 4:37 AM   #39
tbird2340
Originally Posted by No static at all View Post
If I were in your shoes, I would first get a rotator. After installing, if still having problems with KDKA you can try raising/lowering the antenna in 6 inch increments to find a possible better sweet spot.
You could also likely benefit from some very conservative amplification to compensate for the line loss of the coax. The highly tolerant Winegard HDP-269 would likely be the best preamp choice, but still not sure if it can resist potential overload from the nearby locals.
I have personally had better luck when just a small of extra gain is needed using the Channel Master 3414 distribution amp. I've really been impressed with how well it can improve marginal signals in blistering strong signal areas.
Unfortunately no matter what you do, some occasional signal intrerruptions will still likely occur with the weak 2 edge signal from KDKA.
Any recommendations on rotators? How do people get power up to their roofs? That's something I don't think I'll be able to do so I doubt I can even get one..
tbird2340 is offline   Reply With Quote
