Old 4-Nov-2011, 7:01 PM   #41
Billiam
Originally Posted by marni13 View Post
I still can't get ION. I'm not nearly as happy with this Antenna Craft as I was with the original antenna I had. I'm going to get a rotor and raise the antenna some more to see if this helps. If not, I'll look into getting a preamp. Alot of our channels are pixelated, which is very frustrating. We didn't have nearly as much trouble with the original antenna, which I returned!
Which Antennacraft model are you using presently?
You will likely need a preamp in this situation. But, yes first try some additional height to see if that solves the problem.
