Old 3-Nov-2011, 9:20 PM   #7
HDOAinNC
Cool Update
So , took my antenna outside and installed it on a PVC (1 inch dia) pipe facing E to SE.
Antenna is approx 6 ft high from the ground.
It faces clear sky with nothing blocking in front of it
All channels are good, however ION channels seems to pixelized time to time.
Any suggestions ?
Aim toward the E or SE as a start... but take the time to sweep in small steps (5 to 10 degrees) to verify you have what you consider the best aim.
There are a few signals on high-VHF. If you can't get reliable reception of WTVD-ABC, you may need to add a high-VHF antenna.
You have quite a few strong signals close in. I would advise against an amplifier.
HDOAinNC is offline   Reply With Quote
