Old 3-Nov-2011, 5:59 PM   #9
Originally Posted by camou10 View Post
I have a few more questions. What exactly is a rotar and amplifier? and what should I get them?
First, I'm not convinced you need a rotator or an amplifier. I'd try the new antenna, mounted outside as suggested earlier.
A rotator is used to turn the antenna, to allow you to aim the antenna in the best direction for reception of each station. This works best when the antenna serves only one TV and the TV tuner design does not require that you perform a new scan each time you move the antenna.
An amplifier is used to increase the strength of the signals received by the antenna. This is needed when there are long runs of cable and when splitters reduce the signal strength.
If your goal is to receive every possible station, I would change my recommendation to a much larger antenna, a tower to mount it on, a rotator to aim with and an amplifier that would help 'push' the weaker signals down the line from the antenna.
Here are some examples of products that might be appropriate if you choose to go after more than the local signals;
Small to medium size antenna rotator, CM-9521A
Heavy duty rotator for larger TV antennas
Antennas Direct CPA-19 preamplifier
