Thanks
At one time I almost bought the Channel Master 4221 four bay antenna and read someplace that it does as well as the CM4228 eight bay antenna. Maybe the Antennacraft u4000 is better than the CM antennas.
If I get the four bay antenna I guess I could just add it to the same mast as the Radio Shack antenna I have now and combine the signals. I have a large Beech Tree near the antenna I already have up, (on the West side), and thought I may need to move the mast to a better location. Any ideas on that?
Would I need to ground the antenna RG6 wire with a grounding block or just ground the antenna mast?
Sorry for all the questions but there are so many variables I have to consider.
Reason: Incorrect antenna number
