Old 2-Nov-2011, 12:57 AM   #2
If you opt for a single antenna, you'll need a rotator. In the attic, you'll want to use a larger antenna to overcome the attenuation and reflection caused by the building construction. A Winegard HD7696P or Antennacraft HBU-55 for example.
Outside, in the clear, a Winegard HD7694P would do well.
Given two TV's, some people opt to install two independent antennas. One for each TV to avoid the conflict of which way to aim the antenna.
