Old 1-Nov-2011, 6:32 AM   #4
The signal levels shown on your report are fairly low. Low enough to make me think you will have trouble with reliable reception from the attic, especially once the roof is wet... the situation gets even worse with snow on the roof. Attics can work for some, generally when there are stronger signals to start with.
You're correct, higher mounting generally improves the strength and quality of the available signal. Building materials absorb and reflect signal. The best location for an antenna is one free of obstructions.
Your attic sounds like it's easy to get in and out of... if so, try the antenna there. If it works, great, it will last virtually forever in the attic. If you have trouble with reliable reception, you'll need to consider a better mounting location.
Does the 2nd story BDRM have a clear view to the NE?
