The CS4 does very well as a UHF antenna however it's not optimized to give great performance in the VHF band.
Before you spend money on a second antenna, try moving the antenna out of the attic. It may have enough VHF capability to do well when it is clear of the reflection and attenuation of the attic construction.
A few questions;
How many TV's are connected?
Do you use more than one splitter?
If you have more than one splitter, can you describe how they are strung together?
