Old 30-Apr-2010, 5:54 PM   #1
Powerpointlessdave
Springtime reception change?
I live at L0R 1K0 and just put up a 91XG for Buffalo. Specifically looking at NBC 2.1 Ch33. It started out (last Thursday) just smoking! Then over the weekend and ever since has been dropping strength every day. until I am touching threshold occasionally. The only co-relation I can come up with is that the leaves are coming out. Is looking through leaves (with moisture in them) high loss? (Not like satellite Ku band I hope.)
Also if I change the height of my antenna in the signal analysis from 50' (where it is actually) to 10' I get BETTER NM. My best reception should be at 1'! Is this an issue with the calculations?
Thanx Much
Powerpointlessdave is offline   Reply With Quote
