Old 30-Dec-2009, 2:50 AM   #3
Rosa
Thanks for your fulsome reply!
Do you know the make/model of your antenna?
I neglected to say in my initial post that it's a rabbit ears and loop indoor antenna, though you probably guessed that, if only because my radar map says it's 3 ft above the ground!
My first antenna was an RCA ANT301, but it didn't have an amplifier and wasn't very satisfactory. The one I'm using now is, admittedly, an el cheapo model F-6454A by Cornet.
After reading some of the information on your antenna pages, I'm thinking I'll try putting it up higher in the room on a ledge where I could put the VHF legs out flat, rather than in their current V pattern.
Rosa is offline   Reply With Quote
