If you have only one TV connected, try running with no amplifier.
If you prove the need, use a high-input design such as Antennas Direct CPA-19 or Winegard HDP-269. You'll be facing several strong signals that will overload many other amplifiers. If you anticipate adding one or two high-VHF antennas, the Antennacraft 10G221 is another amplifier to consider.
