Old 24-Oct-2011, 7:23 PM   #4
Tower Guy
Originally Posted by frisco View Post
If I have an antenna that is rated to receive channels 2-69, but my Channel Master PAL 7000 just brought in channels 72, 74, 76, and 78, will they transmit through onto TV?
I have seen similar display when stations moved channels and the DTV PAL needed a number above 69 to place a second instance of the same channel. To resolve the problem you can delete all channels and then rescan, do a double rescan, or a factory reset followed by a rescan.
In other cases stations may be adding a data only subchannel without video or audio PIDs. If that's true for you, how the DTV PAL reacts is hard to predict.
