Old 24-Oct-2011, 2:34 AM   #3
MisterMe
Originally Posted by Dave Loudin View Post
Sounds like the DVR is in CABLE mode, not AIR. Cable is distributed using more frequencies than OTA, so the numbering scheme is different.
The ChannelMaster CM-7000PAL DVR receives digital over-the-air broadcast TV transmissions exclusively. It does not receive cablecasts. Therefore, it has no cable mode. This leaves the OP's receipt of channels above 69 as a mystery. Perhaps, a greater mystery is why are his channels not 72.1, 74.1, 76.1, and 78.1. Also a mystery is why is he asking the question in the first place. If the DVR is being used as a receiver, then it is expected to transmit everything that it receives to the TV whether the TV is digital or analog.
